Недавно приобрел этот мотоцикл, 2005-го года.
фактически первый кубатурный мотоцикл.
если что интересно- спрашивайте
Yamaha YQ 50 Aerox R '06 Kawasaki ZX10R Ninja '06
[url=http://userbarz.com/]http://img.userbarz.com/162/32290.gif
Suzuki GSX600F specifications
Dimensions and mass
Overall length: 2,135mm (84,1 inches)
Overall width: 745mm (29,3 inches)
Overall height: 1,195mm (47,0 inches)
Wheelbase: 1,470mm (57,9 inches)
Ground clearance: 120mm (4,7 inches)
Seat height: 785mm (30,9 inches)
Dry weight 1988 to 1997: 200kg (441 lbs)
Dry weight 1998 on: 208 kg (458 lbs)
Engine
Engine type: Four stroke inline-four DOHC, air/oil-cooled with SACS, TSCC. 16 valves.
Piston displacement: 599 cc (36.6 cu.in.)
Bore x stroke: 62,6 mm x 48,7 mm
Compression ratio: 11,3:1
Carburetor 1988-1997: Mikuni BST32 x 4
Carbuteror 1998 on: Mikuni BSR32SS x 4
Starter system: Electric starter motor
Lubrication System: Wet sump
Clutch: Wet multi-plate type
Transmission: 6-Speed Constant Mesh
Gearshift pattern: 1-down, 5-up
Drive System: Chain, 118 links
Primary reduction ratio: 1.744
Final reduction ratio: 3.133
Chassis
Frame: double-craddle steel pipe
Front suspension: Conventional telescopic, coil spring, oil damped. 41 mm inner tube, fully adjustable rebound damping (1998 on: 4-step rebound damping)
Rear suspension: Swingarm, progressive linkage, 4-step rebound dampind, 7-step spring preload
Rake: 25,3 degrees
Trail: 99,5mm (3,9 inches)
Front brake: 2-piston calipers, dual disc, diameter 290 mm (11.4 in.)
Rear brake: 2-piston caliper, single disc, diameter 240 mm (9.5 in.)
Front wheel: 3.50 x17 inches, cast alumium-alloy
Rear wheel: 4.50 x17 inches, cast alumium-alloy
Front tyre: 120/70-ZR17
Rear tyre: 150/70-ZR17
Electrical
Ignition type: Transistorized
Ignition timing: 13° B.T.D.C. below 1500 rpm
Battery: 12V 39.6 kC (10Ah)/10HR
Generator: Three phase A.C. generator
Headlight: 12V 60/55W
Capacities
Fuel Tank (including reserve): 20 ltr (5.3/4.4 US/Imp gal)
Reserve: 5,0 ltr (5.3/4.4 US/Imp qt.)
Oil capacity: 4,7 liter
(копипаст с http://www.suzukicycles.org/GSX-series/GSX600F-numbers.shtml)
Очень хорошее соотношение цена/кубики. Как первые впечатления? 600cm и в-масляное охлаждения? не перегревается если крутить?
Какая цена такого? Сегодня в Мрео встретил чела он Ходну цбр 600 оформлял, год не знаю но мот просто огонь! Брал за 9 т бакинских рублей
да не греется кажеться...хотя пока не очень жарко.
http://www.scribd.com/doc/1960037/Suzuki-GSX600F-Owners-Manual вот мануал на нее
пробег 400 км
все отлично....
я так понимаю, ты еще ТО не делал?
предыдущий хозяин заменил масло и все фильтры.
звезды резина в порядке, жду цепь..
Змінено: 02.04.2009 р., rinatillo
еще забыл.... по возможности карбон поворотники
Публично поздравляю!
http://s41.radikal.ru/i094/0906/a9/da01318407ef.gif
"Проезд без остановки запрещен". Запрещается проезд без остановки перед разметкой (стоп-линия), а если она отсутствует - перед знаком.
проехал уже 1300
заменена цепь, задние колодки, установлены карбоновые поворотники, номер спрятан под задницу.
также сделан прямоток из стандартной трубы)
Апарат зверь. Так за сколько брал?
